hi all, i have a 2004 clio 1.5dci, i resently broke down and called the rac out who diognosed an injector curcuit malfunction code p0200. has anyone come across this problem before and if so what was required to fix it and was it expensive. thanks
Most likely cause either the wiring for the injectors, an injector itself or even the ECU!
I've not had any experience in this particular area myself but have found this PDF on line which explains the test procedure for a P0200 code. Although it doesn't advise how to fix the problem it will give you an idea of where the code comes from.
have a look whilst some one, hopefull, has further information for you :)
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBYQFjAA&url=http://ww2.justanswer.com/uploads/mcvgreg/2008-03-21_223323_1998-S10-P0200-Debug.pdf&rct=j&q=p0200&ei=F8gyTeqMLtOQjAeP0uHmCg&usg=AFQjCNGUGH9OBEW-CJiulYl5dEDhtx4bJg&sig2=Wsp29G8mkivyolL8iCkr2Q
