1 - 9 of 9 Posts
Please could somebody describe symptoms of an dirty injector pump?
Do symptoms include jerking and loss of power?
Thanks in advance.
take face plate off and have a look around fuel temp censor, there the top 4 bolt heads on top off pump remove these and lift off cover plate to inspect but really whats your fuel filter telling you ? is that contaminated ? I'm having problems with my laguna 1.9dti... 1999 with 110,000kms on the clock total loss of power and smoking more than me and mine is the turbo has blown and the cat if i can help any more get in touch........ Alan
It's very rare for dirt or water to reach a fuel pump if the filter system has been properly maintained. Check out the filter first.:)
Dirty fuel pump
If water or dirt has got to the injector pump it can cause serious damage and could cause a load of running problems. Is the car runing OK - if not what's happening and how many mies are on the vehhicle. Sounds like its had a poor service history.:)
The symptoms are the following -
- Engine jerking and making a high pitched noise, not all the time, just now and again.
- Loss of power, not to the point of cutting out but it does lose power, and then speed up again.
It feels like theres a blockage or something like that, the engine holds back and then lets go and it goes fine.
I sugggest you take it to a diesel specialist and ask for a quote and then decide if its likely to be cost effective repair as it appears the vehicle has a poor service record, etc.:)
1 - 9 of 9 Posts
