renault trafic cut out on road renault said number 4 injector u/s new one fitted by mechanic not running take electrics of top runs on three put elecs back wont run does injector need programing to van please help
thanks for that engine runs for 30 seconds fine cuts out wont start unless take elec plug off top new injector then starts runs on three put electrics back cuts out
If you can borrow a noid light to test if the wiring going to the injector is pulsing correctly it may help narrow down the problem.
It seems as if the fuel rail pressure is dropping too low or going to high - either of which will cause the engine to stop or prevent it from starting.
I take it the correct injector was changed - remembering Renaults number their cylinders from the flywheel end - just a thought.
THANKS GUYS got van back after renault saying injector then mechanic snapping injector in head he took head off i spent 100 pound getting machined out all back together still not running he then says renault says it is faulty ecu 580 plus vat so he gives me bill for 1200 pound for work done starts to remove ecu and finds chaffed wire joins it tapes it up now runs perfect all that hassle three weeks later all for a bloody broke cable any one want to buy 06 van new cam belt 3750 all yours i looking for small van astra size good luck guys with your reaults
