Below is a very private way to gauge your loss or non-loss of intelligence. So, take the following test presented here and determine if you are losing it or are still "with it."
The spaces below are so you don't see the answers until you have made your own. OK, relax, clear your mind and.. Begin.
1. What do you put in a toaster?
Answer: "bread." If you said "toast," then give up now and go do
something else. Try not to hurt yourself.
If you said, "bread," go to Question 2.
2. Say "silk" five times. Now spell "silk." What do cows drink?
Answer: Cows drink water. If you said "milk," please do not attempt
the next question. Your brain is obviously overstressed and may even
overheat. It may be that you need to content yourself with reading
something more appropriate such as Children's World. If you said "water"
then proceed to question 3.
3. If a red house is made from red bricks and a blue house is made
from blue bricks and a pink house is made from pink bricks and a
black house is made from black bricks, what is a green house made from?
Answer: Greenhouses are made from glass. If you said”green bricks,"
what the devil are you still doing here reading these questions?????
If you said "glass," then go on to Question 4.
4. Its twenty years ago, and a plane is flying at 20,000 feet over
Germany (If you will recall, Germany at the time was politically
divided into West Germany and East Germany.) Anyway, during the
flight, TWO of the engines fail. The pilot, realizing that the last
remaining engine is also failing, decides on a crash landing
procedure. Unfortunately the engine fails before he has time, and
the plane fatally crashes smack in the middle of "no man's land" between
East Germany and West Germany.
Where would you bury the survivors? East Germany or West Germany or
in "no man's land"?
Answer: You don't, of course, bury survivors. If you said ANYTHING
else, you are a real dunce and you must NEVER try to rescue anyone
from a plane crash. Your efforts would not be appreciated. If you
said, "Don't bury the survivors" then proceed to the next question.
5. If the hour hand on a clock moves 1/60 of a degree every minute
then how many degrees will the hour hand move in one hour?
Answer: One degree. If you said "360 degrees" or anything other than
"one degree," you are to be congratulated on getting this far, but
you are obviously out of your league. Turn your pencil in and exit the
room.
Everyone else proceed to the final question.
6. Without using a calculator - You are driving a bus from London to
Milford Haven in Wales. In London, 17 people get on the bus. In
Reading, six people get off the bus and nine people get on. In
Swindon, two people get off and four get on In Cardiff, 11 people get off
and 16 people get in. In Swansea, three people get off and five people get
on. In Carmarthen, six people get off and three get on. You then arrive at
Milford Haven.
What was the name of the bus driver?
Answer: Oh, for crying out loud! Don't you remember? It was YOU!!
Now you might pass this along to all your "smart friends" and see if
they do better than you did.
