Sorry to hear that. I wouldn't go into that much work unless I absolutely needed to. That means dropping the rear subframe and most likely - the exhaust flexi, just so you can drop the subframe.
If you do decided to do the job. I'd look into changing the bushes on the anti roll bar if they've started to perish. May as well, why you've got the subframe dropped.
