Suggest wiring a 21watt indicator lamp across a blown fuse. Whilst the fault is there, the lamp will be bright, once cured the test lamp will illuminate but dimly. Remove "test lamp fuse" & refit new fuse. Save a fortune on fuses.
HTH
  • Like
Reactions: laurettagiovannini
