Hi all, I have a 2002 1.9d kangoo with a strange fault. More often than not the speedo will stop working while driving and the engine will appear to miss-fire. This can happen in all weather, and when the engine is hot or cold. When it stops working for long periods the engine drinks diesel for fun!! Then, it will start to work fine again, the doors will lock and the engine runs fine.
There is no abs fitted which illuminates the sensors, its got a brand new crank sensor fitted but the problem still persists and is getting worse.
Other problems (which im not botherd about fixing but may help with diagnostic's) is there is no permanet live at the radio, the wipers dont return to rest automatically and the central locking does not work.
The van has been on a computer and apparently no codes came up. I'm out of ideas now how to fix this hopefully somebody has an answer?? Many thanks, Dave.
