I have a 2004 Renault Scenic II. A couple of days ago the passenger side front window wouldn't go back up. After trying the switches on both doors several times it finally went up. The next day the passenger side rear window wouldn't go up so I used the 40amp fuse trick to get it raised again. Today, the passenger side front window wouldn't go up again and nothing seems to work. Any ideas on the problem or why it only seems to affect the windows on the passenger side of the car? Any guidance would be very much appreciated. Thank you.
Hello, check the rubber boot on the hinge side of the door, the wires can corrode inside. This can start with intermittent problems when the wire/s are starting to break up. Hope this helps good luck
