1 - 13 of 13 Posts
I cant tell if my Laguna has been lowered. I only bought it a few days ago. Heres a picture:
I checked the front springs and they are green.
Can someone shed some light on this?
yip donald i agree m8 not lower'ed:)
looks normal to me, but if you're still not sure, next time you see another in a car park, park next to it and compare them together.
They can definitely be lowered. I parked next to one once, and the difference between it and mine was quite noticeable.
Lowering's a purely cosmetic thing, so only you can decide whether or not it's worth the money to achieve the look. Personally, I like to keep my cars as close to stock appearance as possible, so this kind of thing doesn't really appeal.
If I was inclined to do anything with your car, it'd be to go for some bigger alloys to fill the arches a bit better without adjusting the ride height. 15" just look far too puny on the Lag, and I'd say it takes a minimum of 16" for it to look sensible. You might just snap up a set of standard 16" from someone who's decided to go bigger, or you could bit the bullet and buy new 17" or possibly bigger. If you're buying second-hand, then remember that some Lag 1's had 4 stud wheels, while others had 5. Make sure you get the right ones.
I wouldn't even contemplate lowering any car if you ever plan to tow with it. Even if you don't, killer speed bumps will become more of a problem. From a handling point of view, it may make it better or it may make it worse. You won't find out until you give it a try.
Discussion Starter #11
Would the laguna 2 alloys look good on the laguna 1? what alloys would look good? which size af alloy and tyre would be the best for the car?
Again, it's up to you as to what looks good, and whether it's worth the cost. Check out the following link (found on Google) and it's showing the same part numbers for the 5 stud Lag 1 and the Lag 2, so wheels off the Lag 2 should fit. 19" appears to be about as far as you can realistically go, though looking at the prices will probably make you want to compromise on something a bit smaller anyway.
Renault Alloy Wheels - Alloy Wheels - Specialist supplier of alloy wheels and tyres packages, 0% Finance and Fast Delivery
If you go for Lag 2 alloys, then most of the 17" ones on offer will be the Silverstones. Beware, as these are notorious for being made out of silly putty and buckling if you drive over a pebble at more than 10mph.
RIP 31-12-2008
Hi there, GFS, GSF Car Parts, cheap car parts direct to you stock lowering springs for the front of your Lag (35mm drop) at £45.00 each + vat,
however, if you wish to lower the rear it will mean adjusting the torsion bar as there are no springs and this will mean the use of special tools to re- adjust the suspension geometry,
Regards Leroy
1 - 13 of 13 Posts
