Is there such a sesnor that controls three functions (the airbag check, oil pressure check and sone other that I can't remember) during start up? This sensor is apparently under th bonnet somewhere and was replaced on my Espace today when it went in for a clutch master, slave and the clutch itself. Can't remeber the reason he changed it, but I was just talking to him about the airbag light when picking the car up and he told me about the sensor he replaced which controls these three functions. So hopefully, after a reset, the airbag light might not come on again?
Just curious where or what this sensor is? Will try a reset tomorrow (battery off) and if it works, it might be useful for others who have tried everything else to try and cure the airbag warning but have failed like me
The air bag would be checked by the srs ecu. And the oil pressure by an oil pressure sensor. can't really see them being combined into one. unless data is being shared via a bsi unit.
