Hello all of you..
i have found in Megane and Clio with the k9k (1.5dci) engines two different crankshafts....well, they are not different except for one thing. On flywheel side of the crankshaft there is a positioning (center) for the flywheel. this is aprox. diam. 47mm.
In the center are two options:
1- there is only 16mm hole for the drive shaft of the gear box
2- it is a two step hole, first diam. 40mm/13mm deep and then the same 16mm hole for the drive shaft.
Renault only supplies the latter 2-shape crank but i can not find anywhere which crank is put in which k9k engine. it looks like it is random but i cannot believe that.
any one who knows ?? somebody who swaps engines must have seen this also.
thanks.....
thanks.....
