Does anyone know if a Renault kadjar 1.2 tce 2017 has a fuel cut out Switch or how to reset the fuel to the engine
All airbags now replaced and cant get it running
AFAIK, all later Renault models have software lock outs that trigger if airbags are deployed.
You will need diagnostics that speak Renault to track down exactly what on the Kadjar and reset.
you may have to do some ringing around, unless you are a key worker (NHS food chain industry etc)
it may be difficult to get a garage to look at your car. Needing a car to do bulk shopping is not a necessity in this time of crisis.
Al
Computer will be locked by air bag, New air bag module; has this been fitted, or crash data removed.
You need to Go into The UCH and unlock the computer.
Need something like Clip..,
Airbag computer was sent away for repair and is now clear all airbags replaced but still not running, crank no start
The fuel is also getting through to the engine bay as I've unclipped the pipe to check
I have a clip tool does anyone have an idea where I find the problem through clip
look in the uch, computer locked by air bag
then check injection, then abs
no fault codes?
