Hi all, I hope this hasn't been covered before, & I apologise
if it has, but I can't find the thread.:crazy:
My 2001 Kangoo Helios Est. has developed a clutch judder, when pulling away in first. I've had it from new & it now has 55,000 on the clock. I've been experiencing this for the past 3 weeks & it appears it could be getting worse, I just hope that's my imagination:confused:
Any ideas/help/advice would be appreciated.
BeeJay
Clutch judder is usually caused by the following things...
A worn or broken engine mounting
A clutch plate which is contaminated by oil
The face of the flywheel has gone slightly out of shape
A sprung loaded flywheel that is worn(not sure if your car has one of these)
A clutch plate that has worn torque springs in it
I'd start by having the engine mountings check and go from there.:)
