Hi Lads,
re: 1.4 petrol 2000 Kangoo
Over the last few weeks I could hear a humming/buzzing noise coming from the rear of the car while on tickover.
When you switch the iginition on you could hear the same noise for a few seconds when the fuel pump was pressureising the system.
I was getting the car serviced & asked the mechanic to look into the humming noise. Got a call to say the bearings are going on the pump & it needed to be replaced. I was also told it was a big job, tank had to be removed, 3 hours labour
Anyway, I said replace the pump. I just got the car back & I can still hear the buzzing noise, it's slightly different but still there?
I'm now aware of the inspection plate that's under the rear seat that allows you to access the pump. 3 hours seems a bit rich for replacing a fuel pump that you can get at handy, what do you guys think?
The buzzing noise is my main worry, I'm sure they put a new pump in, so if the pump is not causing the buzzing noise what could it be? Petrol tank mountings? Blocked fuel filter (or is this built into the pump?
SO, I have two issues:
1. Do you guys think 3 hours is OK for replacing a fuel pump on a petrol Kangoo?
2. IF the fuel pump was replaced with a new one, what could still be causing the humming/buzzing noise?
Thanks in advance
Thanks in advance
