Discussion Starter #1 (Edited by Moderator)
My only working Kangoo key has fully given up the ghost. The LED doesn't light when button is pressed, the central locking doesn't work (obviously), and the immobiliser stays on.
I thought the switch might be at fault so I desoldered a known working switch from another ebay key and soldered it onto the original key. Still no LED when the button is pressed... :loser:
Anyway, my question is this: if I take the transponder chip off the original key and solder it onto my ebay key, should I be back in business? Has anybody tried this who might be able to advise?
P.S. I take it that the transponder is the item arrowed in the photo below?
http://www.imagebam.com/image/9d7af375604510
the chips on the PCB are coded.
the bit arrowed looks to be an antenna?
there is a guy on here that does key fob card repairs, do a search.
