:crazy: Hi,
My 2001 1.4 petrol Kangoo's tappets need adjusting.
As I can't get a Haynes manual for this vehicle, can someone give me the settings for it & how difficult/easy is the job.
Thanks in anticipation.:)
I'm not sure what means of adjustment they use as I've never done them,but the settings are...
Inlet:0.10mm
Exhaust:0.25mm
(Both with a cold engine)
Hope that helps.:)
Hi Lagdti,
Thanks for your reply & info. I've sent you another poser on the engine site, with regard to the removal of the Top Dead Centre sensor, that I think is causing a problem. Once again, many thanks.:)
