My 1999 1.9D kangoo van speedo is being very erratic. It works for a while then stops for a while. I have had the dash apart and can see nothing amiss there. Is there anywhere else I should check and what could be causing this?
Hello, I know it was a while ago but did you find a solution to your speedo problem? I am not getting anywhere with mine, and no one seems to be replying.
La sola lupo
Did you check the sensor on the gearbox and the wiring to it?
Hello, thank you very much for your reply, I have looked at the gear box and I can't seem to identify the sensor, I have looked at photos on this site but my gearbox does not appear to have a sensor on it, the van is a Vreg, and it does not have ABS, any idea what I can try next? or how I can identify where the sensor is?
Thank you
Sid
La sola lupo
Since i'm not based in the UK saying its a v reg doesnt help me much.
If it doesnt have ABS it must be cable driven or have a sensor.
Is it Manual or automatic?
On the manual box the sensor is directly above the "dogbone" mount, or if you look from the top, where the engine and gearbox bolts together look toward the back and you will see (or feel) it right on the end of the gearbox casing
