Hi guys been changing the rear brake shoes on my kangoo.
i got one side hub off fine but the other side was a right ***** and when it came off it left the rear of the wheel bearing on the shaft , i pulled it off dropped it back in the hub and hit it with a large socket to try and press it back together however i now seem to of bent the little collar part that holds them together... can i ask is it common for these to part or when the back end of the bearing separates does that mean its had it and needs replaced ? many thanks
remove the collar
Now slide the back bearing on the shaft,,,,put the drum back on, and as you put it on, spin it
Now you can tighten it up as normal.
The centre part ( Collar ) is to hold both parts together nothing more
  • Like
Reactions: Davegayle
Ok thanks mate so once the hub nut is back tight every thing will hold in ?
Just to get the wheel back on tonight i put it back togeather like you said but i left the collar part in the middle
would i be better to take it back apart and get that out ?
If the collar part has not gone around both tapers you will have issues
If unsure Take It out and ignore
