Hi i have just bought a kangoo 2002. spanish spec. 1.4 petrol.
Central locking didnt work so i removed battery b4 checking my data cd to find that because i fiddled for more than 10 minutes the immo had activated and hence the car wont start. immo light flashes it is deffinately the immo because the car was working prior to my fiddling. i have the 8 digit code inside the key and was able to find out the 4 digit reset code. Marvelous. I trotted off to the garage to follow the instructions that i got with the software that gave me the code and done as instructed. Hey presto the engine started. BUT then i turned off engine and tried the central locking. the C/l worked and so i tried to turn over and the car wont start again. it says emergency code on the software instructions. does this mean it only works once or did i only do half the job. i did find the instructions a bit strange to follow. please help. douglas bader
Hi Doug.
As far as i understand it you need to enter the manual code for the immobiliser each time you start the car.
Hope this helps.
