Hi Guys just a simple question, can the laguna keycards only be programmed by renault dealers/garages or do you know of any other places who could program them. My local renault dealer quoted 80 quid just to programme a card, thats ridiculous to say the least, would the aa or rac have the equipment to do this? cheers guys
Hi vajid, do a search in the forums for keycard and programming ... plenty of info out there, cost of "re-programming/synching" is a common moan with dealers.
Hope it helps:)
Hi Have a read of this
As of 4 June 2006 You will NOT be able to buy a new keycard from Renault without supplying the VIN number and proof of ownership of the vehicle..
The following vehicles are involved:
Megane II, Scenic II, Laguna II, Vel Satis, Espace IV, Clio III
The reason behind this is due to a major security issue that has been discovered outside the UK.
This is the theft of customers vehicles.. The senario is this. You take your vehicle for some work to be carried out. The Dodgy technician has a blank keycard. He programs that keycard to your vehicle. Then the either comes to your home address and steals the vehicle or sells the key and the address to a friend who then steals it..
So the procedure is that you or us a dealer has to provide customer specific details to Renault France who will authorise the card to be ordered.
The card then arrives at the dealership with your VIN number already coded to it. We then apply to Renault for the programming code and have 1 hour to program the key before the code expires.
So if anyone is considering buying a New key from Ebay for example. You will NOT be able to get it programmed fullstop as the Clip will not allow a non Vin encoded key to be programmed as explained above..
Note also that a new Vin encoded key Cannot be programmed to any other vehicle even it is has not been prgrammed to the origional one
Ottoman
