hi having a problem when i go over bumps in my megane there is a knocking noise just been around and pused down with a bit of force on the suspension the rear passanger side does not seem a smooth as the other's there is i noise coming from it do you think this is where the knocking noise is coming fromand what can i do to stop it? lubricant?
The older style Meganes have a tendency to snap rear shockers,but I'm not sure if that is the case on the newer shaped ones like yours.
I'd get it checked out asap......
i don't think it is snaped it still goes down and then comes up but there is a slight grinding noise. not smooth
It still could be a damaged or snapped shock absorber,but could also be a broken coil spring or worn rear bushes.I'm not sure on the type of rear suspension that the new Megane uses so can't give any specific information,I'm afraid.:(
