Hi i had a new wire put on the dvrs window and the car was fine working window great..all the wing mirrors work fine and all the other windows just the dvrs one i have probs with. it goes up and down the inch or 2 at a time have done the 2 sec pull up the window worfs sometimes ok then back to saftey mode, i have read around but no real posts other what i have read about the reset, has anyone else had this problem and any fix for it...the regualtor and wire are fine no probs getting stuck or anything...
Does the window move up and down smoothly and quickly?
If there is a slight restriction the window may think there is a problem and keep cutting out.
Some silicone spray in the window rubber seals may help things.
