laguna 2 dci 120 fan location and fuel guage
:steam: hi all my fan is not blowing out of the vents
very well on any setting fans working ok and maybe the main part is not conected to the vents or is just ? any help as to wear in the dash it is ? also my fuel guage is reading full all the time,i have checked connections on the display,
oh and can i disconnect the tyre pressure sensors,as they are doing my head in,
for info this car had its turbo blow with 72 k and no warranty.. but i got reno to pay for it
Hi Shoggy - have you checked the pollen filter because if it's blocked no air can get into the system. Exactly what is wrong with th etyre pressure sensor system.:)
bee-hive
cheers me dear i will take it out and give it a good shake then(oh well the hell is it !) and the sensors are just normal flashing when it gets a bit wet and as i check them every week it it is just anoying when they keep flashing for no reason
