with impeccable timing as the MOT is about a fortnight away, my goona has (I suspect) taken it on itself to break a spring. Was sat outside fixing my pushbike (how apt), when there was a loud metallic bang and the front right of the car had visibly dropped an inch or so. Yet to investigate properly but suspect the bottom turn or so will have sheared off the front spring that side...if so, and I can retrieve it and the remainder seems located ok-ish, safe to drive to a garage or is it a recovery job (or home repair)?
