Hi chaps
There's some crackle coming from either the mids or the tweeters. Does anyone have the dimensions for the speakers so I can check out possible replacements?
Cheers!
130mm! Just pull the speaker grille/cover off.
Be careful with the depth though as too deep/big a magnet and it will interfere with the strenghtening bars in the door!
Cheers ST. Some noob questions to follow....!
The 13cm component kits on http://caraudiosecurity.com often have additional crossover components - will all the kits need this or can you use the built in one? Or else where is the crossover to swap it out as well?
Are all tweeters the sam size?!!
http://caraudiosecurity.com/shop/product/products_id/2962.html
These look good - depth I can compare against the existing set, no mention of a crossover. Just guess I have to hope the tweeters are fairly standard...
... although this set mentions Renault ...
http://caraudiosecurity.com/shop/product/products_id/1268.html
....or
http://caraudiosecurity.com/shop/product/products_id/4826.html
:d
