1 - 11 of 11 Posts
Hi all.
I gave a 2010 Laguna 3 which has just passed its' MOT. However I was expecting it to fail as it has an annoying rattle at the front.
Here in northern Ireland the MOT test centres put your vehicle on a ramp with moving plates and play a game of "lets try to pull your car apart". I may be the same in GB. I said to the tester that I was surprised it had passed and he reassured that everything they check was sound!
I have tried to locate this annoying knocking several times. It is most evident over poor surfaces at around 20mph.
I'm now thinking rear or left engine mount. Any pointers from the wise out there, or even the men :rofl: would be much appreciated.
Thanks in advance,
Simon
if the gear lever moves when the knocking is occurring check the dogbone mount at the back of the gearbox.
Could be the brake caliper pins try just touching the brakes see if the knock changes.
did you hear it knocking when it was on the vibrating plate for the MOT?
  • Like
Reactions: srafferty
Worn out Wishbone Balljoint can also make knocking. And will make your tyre wear out quicker then norman.
If you struggle to feel anything lose with the car jacked up, it can help to check the toe angles in reasonably step up hill and downhill slope. Make sure your have the steering wheel centered always (a bubble levere helps) and compare the numbers you get from the uphill Vs downhill facing checks.
To measure use strings connected to the rear rims. Pull tight and measure between string and front tyres if any of the front wheels are of straight forward toe angles..
Worn out bushings will also make the toe angles differ slightly.
Sent fra min Moto G (5) Plus via Tapatalk
Discussion Starter #11
FIXED
The car started to handle like a shopping trolly, so I had to stop driving it. This turned out to be driver side front wishbone bush. Since this requires dropping the subframe, I decided to do both sides and ARB bushes while it was off. All done and the knock was still there. Drop links weren't that old and felt OK. Spring not broken. So I came to the conclusion that it must be the upper strut mount. So having purchased a replacement I went about dismantling the strut. That's when I found the culprit. The shock was completely done. This hadn't occurred to me as I had bounced on the wing a few times to check it and it appeared to be normal!! New shock and now driving like new. So I don't know how it passed the MOT.
Simon
1 - 11 of 11 Posts
