:d Hi all newbie here in need of some help.
I have a 1999 laguna 1 exectutive 2.0 (n7q engine) which refuses to start.
Car has been of the road for a while but was started regurly untill a couple of months ago.
Tried starting but engine turns over but wont fire up. Have just replaced coil packs but as these often fail after standing. All alarm seems to work ok lights go off as they should. When i sprayed easy start into air inlet it fired up abit but would not start properly. Have bypassed the fuel pump relay so i know pump is ok and have changed the relay. Have checked all fuses and connections. Is this something to do with the immob. Before this the car was running very smoothly with no problems at all.
Hope somebody can help.
Cheers
Cheers
