How do I remove a drive shaft (Drivers Side). I have followed the Haynes manual to a tee, but the Driveshaft does not come out gear box end....any tips?
I'm not sure of the type of fitting on your particular model but you may have the type that is held in situ by a small metal pin. If this is that case you'd need to get a very thin implement to knock the pin out to be able to remove the shaft from the gear box........hope that helps!
