my laguna 1 front brakes have started to vibrate and get very hot(on 1 side) i have stripped them down and the caliper and guides pins are free , but i have noticed the inner pad is contacting the inner and outter of the dicc that is where the heat is comming from everything is tight but i have heard some of the pads are offset and are slightly different to each other could it be the case that the inner and outter pads are on the wrong side?
Laguna 1 Front Pads
The pads i have just bought for my 3.0l Laguna are identical for inner and outer except that the inner ones have the wear sensors fitted.
This ties up with the description in the Haynes manual.
TBH I don't quite know what you mean by the pad only touches the inner & outer of the disk. Do you mean the inner and outer edge? If so, it sounds like that you have severely worn disks that should be replaced.
HTH.:)
