hi guys just a quick one does anyone know where the position of the heater resistor is on a 04 plate laguna 2. the fan only works on 4 so was told that was the problem but not sure where it is ? cheers steve.
If my memory serves me correctly the ballast resistors are just above the heater blower motor. Try removing the glove box and having a looksee.:)
the resitor pack is inside the blower assembly - not through glove box, accessed from underneath. Pull down the thin cover (Velcro) remove cables, 2 bolts, turn cover anticlockwise to remove. Resistor bank is held by 2 bolts, within that.
:d
