i have a 1995 renault laguna replaced bulb in dashboard clock it worked fine then battery went flat and now just have a light that works but no display
do you mean the radi/temp/time display? have you got a standard stereo fitted. when you get a flat battery it is normally only the radio code that needs re-entering, if you have a non standard radio this could be the reason
As above, although a funny thing happened to me last week.... the steering remote stopped working on my 2000 Laguna as well as the display. Switched the car off and back on and all was fine again!
