Hi All
My until now flawless laguna has developed 2 faults in 1 week.
1st fault - Handbrake error, this happens when applying the auto brake, and is accompanied by the service light, thing is the handbrake appears to work fine (it holds the car). First time I remember seeing it is after going over a couple of steep speed humps, so maybe something has come loose? a sensor maybe.
2nd fault, happened yesterday - engine cut out, and check injection came up, then car went into limp home mode, had it checked out and found it was a stuck open EGR valve, had this replaced striaght away, and all seems fine now, just wandered if I could expect anymore trouble with this?
Sorry if these have been posted before, I did look around, but could find an answer to my question, so if there is one, could you point me in its direction
Cheers
Mark
Cheers
Mark
