1 - 1 of 1 Posts
I am about to change the clutch on my Laguna 2 the only fault is the clutch slipping but I am also changing the hydraulic thrust bearing my query is as the bleed nipple on the thrust bearing is all one plastic mould it looks as if it is an automatic bleed so can someone tell me how I bleed this I suppose it is just to fill the master cylinder(brake / clutch) until the fluid comes out of the clutch pipe then link it into the thrust and with a pipe on the plastic bleed nipple pump the clutch pedal until fluid comes out am I right or wrong
Thank you
Dave
1 - 1 of 1 Posts
