Hi, can anyone help me with my instrument cluster problem? I have read that people have had problems with this before but not sure if its the same one. whem i put my card in the instruments dont move. then as car warms up the instruments come on then off as if ive just put card in. eventually it settles and the cluster works fine. a friend of mine had the same prob. renault changed the cluster but it turned out to be a loose connection in battery area! think might be same on mine with a power supply problem, but have checked battery connections. fine. fuse box/relay compart in engine. fine. Could it be a loose connection at the back of the cluster, or is it more likely to be a component in cluster? also ABS light has just come on. MOT due end of month. renault lpool cant fit me in til 4th april. typical. any help greatly appreciated. thanks in advance. John.
