Hello,
I have a set of electronic based problems with my Laguna 2,
1- No warning tone when leaving car with lights on.
2- No clicking sound when indicators in use.
3- No heater display backlight.
4- main roof light doesnt work when front door is opened.
I think the problems are all connected. Does anybody have any idea what the problem could be, would really appreciate some help on this one
Hello,
points 1 and 4 are probably a duff micro switch in the door lock assembly.
point 3 presume you have climate control: theres a thread on here how to repair - really easy. will search for it soon
number 2 - no idea
Diamond dismember
If the puddle and footwell lamps still come on when the door opens, number 4 can't be due to the door switch.
As for number 2: Do the indicators flash quicker than normal?
If so, faulty connector to the rear light cluster on the side where you have this problem is likely.
With the heater backlight if i remember rightly it is normally a problem with node "101" I had to do it on my old laguna. Just needed a soldering iron over it to repair. Took me 20 mins to do roughly and that included getting the panel out of the dash. :d
With the other problems i have no clue sorry :(
