My trusty Laguna has several issues that have surfaced over this weekend.
1. 'Oil' is leaking from the bottom of the gearbox bellhousing - it is very thin, and does not appear to be lubricant - more like brake fluid. I have a tray under the car tonight to catch anything that may drop
2. Brake warning appeared the other day whilst braking very hard - new pads in January and everythin ok
Does the car have a hydraulic clutch, running from the same reservoir as the brakes?
M9R engine
Is the oil in the P4k box thin?
3. Both front tyre pressure sensors failed on saturday, replaced temporarily with standard ones. cheapest deal to get the tpm sensors replaced is £140 from four ashes renault including programming
I have already fixed the window regulator last year. I love the car, but im used to reliable Renaults, not like this one
M9R engine
