Hi friends,
My Laguna 2 year 2003 has an illuminating airbag light in the display.
Diagnose shows error code DF073.
I have checked all the connections under the seat, and even soldered the connections together (it worked on the opposite side when the same problem occured).
My question: I will try to replace the pretensioner (the one with buckle), but can I use the pretensioner from a Renault Scenic? A quick look at the photos here and the almost look the same apart from the female connection that is "twisted" 90 degrees?
Laguna
Scenic
https://www.ebay.co.uk/itm/Renault-Scenic-2003-2006-Driver-Side-Front-Pretensioner-Belt-Clip-550588300A/283006695702?epid=650774283&hash=item41e4837916:g:Rh0AAOSwOyJX2V8Q
what side of the car are you on, as that is passenger side of the car..
DF073 (DTC9004 ) Passenger's side buckle pretensioner circuit
Would say no, to using anything other than a Lag II air bag system for a donor part,,
