Hi all,
I bought a 2002 Laguna 2.0l touring auto a couple of months ago and all has been ok until now. I drove into town, pulled up to wait for someone, switched the engine off and left the card in the reader. When I came to start it; nothing! I checked fuses, battery etc then called the AA.
The bloke from the AA checked fuses, tested and boosted the battery, still nothing so towed me home.
Having found this amazing resource I checked through and find quite a few similar problems but so far none of the checks have resolved anything.
Here are the symptoms; When inserting either key card the audio display lights up but nothing else, other than initially the dash display asks me to' insert card' which is already inserted. The red immobiliser light stays illuminated but absolutely nothing else. The AA bloke said it should have 2 stages to ignition but mine was not even doing the first. I understand a new card reader may solve the problem but then worryingly hear it may not. I cant afford to pay main dealer prices as I'm out of work so any ideas would be greatly received.
Also having read about the UCH problem I'm now worried it may be that, the reason being when I removed some of the lower dash panels there are signs of rust on the metal work around the area of the fuse box. I guess the last question would be can anyone recommend someone who would be able to diagnose the problem? I live in Huddersfield. Thank you for taking the time to read this and any potential advice would be greatly received.
