hey guys can anyone help me, i have a renault laguna 2003 and im having problems i have 2 warning lights on the airbag and service light as well as the little spanner is flashing are on, any ideas how i can switch them off??? cheers guys
The lights are illuminated because the ECU has detectd a fault and is recommending you have the fault remedied by a garage.
The warning lights can be extinguished only by using a Renault compatible diagnostic kit but extinguishing the lights only cures the symptoms and not the underlying fault. I suggest you get the faults correctly diagnosed and then worry about getting the warning lights sorted.
