Hi, the instrument cluster led display is acting up so I want to remove. Looks like a plastic cover and two nuts/screws holding in place. Can anyone tell me how I got about remove, including unclipping that plastic bit.
Tom
Ok so I decided to have a go at this and got it removed, without removing the dash. Steps below.
1. Loosing two screws under steering column, this will allow to split top and bottom sections surround.
2. After removing these, there is a screw in the center for the adjustment this needs to be removed as it holds a plastic piece at the top and to unclip the section i mentioned in the photo it has to be able to pull forward
3. Unclip the back piece mentioned above and in photo, need to pull forward the piece mentioned above we just removed screw on. Then wiggle the unclipped plastic piece nearest the cluster to remove
4. This should now expose the screws holding the cluster and is simple removal then. Mind the cable connector
