1 - 8 of 8 Posts
Hi.
I want to change both arms on my Laguna. Can't be arsed dropping the subframe so does anybody know what bolts I need for the rear of the arms and where I can get the?. I intend to cut these and then put in the replacements from the bottom. Not ideal but will do.
Thanks.
Mark.
5 days old and still no reply.....Wow.
Usually means it's not a common job, or even a common car amongst owners on this forum. Just wondering why you want to change the arms. But, regardless of why, I'd suggest a Renault dealer for the bolts, as a first port of call.
HOW would anyone really know.
Never heard anyone other than you OP wanting to do it this way
There will be a reason they are hanging down
Its usually, if the nuts work lose then the bolts can drop out
Or not enough room to allow bolts to go up bank and have enough thread passing through the nut..
I don't have a Laguna, but I just watched a YouTube on how to do this, so I now understand what you are trying to do. They used the same bolts, just got them out by moving the subframe a little.
1 - 8 of 8 Posts
