Hi all,
I've a 2009 laguna 3 and an abs fault appearing on the display. My computer won't access the abs module although in most other modules they're faults appearing referring to the abs. So I'm thinking would it be the abs module or a wire broke somewhere?
In engine,
DF091: Multiplex vehicle speed invalid.
DF1012: Multiplex signal for cc/sl
When checking the can high line I've a resistance of 88ohms rather than 60ohms. Just wondering have any of you came across these faults before or can point me the correct direction where to look?
Your computer can't get anything decent as ABS modules are usually very well covered in diagnostics, there are lots of sensors in the system.
From description, I would first look at ABS sensors on the wheels.
