1 - 10 of 10 Posts
I have read on here that renault's new spec for the laguna dci is fully synthetic 5/40 engine oil, is this correct, i also noticed looking around you can get different quality of this oils cf and ch and ch4, i would like to know if the cf grade is ok has i do change the oil every 6k. Reason i ask is there's a big diffenece in price between the cf and the better quality ch im not sure what the ch4 is either .
Discussion Starter #2
im looking at fitting with either 5/40 synthetic or using 0/30 synthetic which would you recommend, any renault tech like to give us some advise please.
here is the spec that renault fit to dci which is cf rated.
ELF Excellium LDX 5W40 Synthetic motor oil - A high performance fully synthetic oil designed for high RPM use and protection at extended change intervals. Meets the following ratings: VW/Audi 502.00 and 505.00, BMW LL-98, Opel/GM LL-B-025, Daimler/Chrysler 229.3, Porsche, ACEA 2004 A3/B3/B4, API SL/CF. 5 Liter jug.
1 - 10 of 10 Posts
