Can anyone tell me what the following sensors are from the attached picture or if I am correct.
A) Knock Sensor
B) Not sure if this is the oil level sensor, it only has 1 wire to it(there is another mysterious wire hanging nearby which I am not sure what is for.
C) Oil Pressure Sensor/switch
D) Coolant temperature sensor
Also is the air temperature sensor in the intake manifold or throttle assembly.
Thanks for you help.
A) Knock Sensor
