Scenic mk1ph2, RX4, ID35s11
tyr here, you might be lucky:d
failing that trawl ebay and contact the breakers yards advertising on there direct.
laguna/megane/scenic/espace/clio often share engine/gearbox parts
Discussion Starter · #3 ·
after speaking to a renault breaker he confirmed that the 010 will fit straight in all the difference between all laguna gearboxes are they done two different gear selectas as long as i have the right gear selecta it will fit in the gear ratio is a little bit different but i wont notice it he said so i have brought a 010 and will reply back on it he said the correct one i need a 015 is rare and hard to get hold of
