Hi, I was wondering if anyone could help me out on the following problem.
Whilst stuck in traffic lights my car had a fuel injection fault. The warning light came on with the esp fault. Then my car had a stop red light and it shut itself down.
From researching this forum I can see that it might come down to the fuel pressure regulator or fuel sensor. From someones advice I took of the regulator and left it in carb cleaner over night. However if the car runs on idle for more than 25mins the fault will happen again.
I've been running my car with aircon on and everyime I come to a set of traffic lights I turn my car off. This seems to be helping!
Anyway.......
I went to my local garage the other day and had a diagnostics reading. It came up as follows :
1) 116 - Thermoplunger number 1 relay control circuit open or short to earth current
2) 175 - hermoplunger number 2 relay control circuit open or short to earth current
3) 142 - Fuel Pressure sensor circuit open - current
4) 184 - Fuel pressure regulator incoherence current.
I dont know what any of the above means?
Could anyone help out with the codes?
Is the fuel Regulator the problem?
What the hell is a thermoplunger?
I don't want to take my car to renault as they have quoted me £600+ to fix when my car is only worth £1000
Cheers for any help!
Anyway.......
