Hello
Got in my laguna the other day and fired her up, went to drive away when a warning light appeared on the dash. The light flashed on and off for about 10 seconds. During this period the car was low on power and would not achieve a speed greater than 30 mph. After this the car picked up power and everything was fine after this. I looked up the warnig light and it appears it was the electronic fault or water in diesel light.
Decided to clean the egr valve and also drain all the diesel out of the filter, but after this i took the car out again and the same thing happened.
Does anyone know what may be the problem?
Any help much appreciated.
