1 - 11 of 11 Posts
My first post on a great forum...been reading threads and the help and support is fantastic.
I have what seems to be a silly question.:confused: ..How do you reset the clock in my Laguna II? I have a 1.9 TDi Techno (2003). In the manual it refers to buttons on the dash in front of the radio/clock but there are none. What am I missing??
Thanks in advance..Ozmo
Hi and welcome to the forum is it done through the radio this is just a guess ian not sure i would say there should be buttons as you said.If not iam sure somone will help soon all the best Donald
There are two little pen holes under the clock display - the left one changes the hour and the right one changes the minute
Hope this helps
If you have a built in sat nav, the screen/clock is different and it will be adjusted by the menus for the setup screen.
Otherwise if you have a standard clock/radio display it is as mentioned by two tiny switches - you need to use a pin or similar to push them in as they are recessed.
Cheers for the responses adamfield and SportTourer .I couldn't find the pin holes but I do have a built-in Sat Nav so I guess I'll check through the menus. I've already tried this but obviously missed it. Thanks again....ozmo90
Banned
No question is silly, if you don't know the answer and like SportTourer Say's with yours the answer is, within the SN mines the same. :)
No problem.
We are all here to try to help. Your question wasn't a silly one, just a reasonable request for help.
We have a standard display in our Privilege, so hopefully someone with the Sat NAv will be able to tell you the required sequence to get to the menu you need.
sure m8 i have the same car,
go into the sat nav settings menu and you'll find the time/date setting within the sub menus :)
from memory i think its just a couple of presses in :)
the numbers will show in the screen and you can scroll through and press the right hand knob to select :)
you'll soon get it m8 :)
Discussion Starter #10
Hi Torch DCi,
Easy when you know how. Thank you so much for that. I'm no longer turning up late for work (..don't know if that's a good thing or a bad thing..).
Cheers again mate
my model is adjusted using the satelite cd/radio controls on the steering column press the two top buttons for a second or two then use volume control to set desired time *stereo must be off*
1 - 11 of 11 Posts
