I've only posted on here a few times but yet again its with yet another problem.
For some reason the car seems to be cutting out randomly, usually when freewheeling or coming to a stop. When trying to restart it takes 2-3 seconds of holding the starter button and pressing the throttle to get it going.
Also when trying to start it, it now requires the above procedure to get it going.
Hopefully it will be an easy and cheap fix (but more than likely it'll be complex and expensive!!)
Any help would be appreciated.
Cheers
Stuart
Hi sorry to here your having more problems it maybe worth putting in a search under TDC sensor to see if this helps you any all the best Donald
