I thought I would start up a thread about my attempt at repairing my Laguna II 1.9 DCI, and hopefully I will try and make updates on my progress.
The timing belt snapped last year and Im hoping all that needs repairing is valves.
Now the weather is getting better and the nights are getting longer im going try and get the car back on the road.
So far I have removed the auxillary belt and have started on the timing belt cover.
I believe that to get the timing belt cover off I need to remove the crankshaft pulley that drives the auxillary belt. Two things I have noticed, firstly the auxillary belt seems to have fraid and bits of it were wrapped around some of the pulleys, and secondly there was a broken bit of metal casting wedge behind the the crankshaft pulley, not sure where it came from at the moment.
I have two questions to start with;
Do I need to take the auxillary belt crankshaft pulley off to remove the timing belt cover? If I do what direction does the bolt need to be undone, is it opposite threaded?
Do I need to remove everything that the haynes manual tells me to to get the head off the engine? I have been told that it could be simplified a bit?
